RCU Forums - View Single Post - Does the RealFlight controller work for AFP/AFP Deluxe? Yes it does!
Old 01-18-2006 | 03:55 PM
Rick Delten's Avatar
Rick Delten
Default RE: Does the RealFlight controller work for AFP/AFP Deluxe? Yes it does!
ORIGINAL: Rob777
AFPD using G3 controller are the dual rates, flaps, idle up, and throttle hold programmable?
Great question Rob!
So far I have been able to program the G3 controller to operate all the regular control surfaces (rudder, ailerons, elevator). I have also been able to get the gear to go up and down w/the 2position switch on the upper right of G3 controller and control flaps with the rotary knob below that switch.
I have not been able to set-up the 3positon switch properly because it seems that AFPD only recognizes 2 of the 3 positions. I also have not been able to figure out how to set up the other 2positon switch to function as a high/low rate switch.
Anyone else have better luck?
