XXX NT problems.
Losi XXX NT RTR sport 2
On the stock mach .15 engine it pushes fuel out of the top of the head but I can't tell that its coming out around the glow plug for sure, what would cause this?
It does it mostly when I'm trying to start the truck, if it starts, it doesn't seem to do it. It happens quickly so its not like its flooded so badly that it starts to do this, if that makes sense.
2nd, when the truck is running it doesn't freewheel enough at idle to let me sit it on the ground w/o it dying.
I checked the clutch spring it looks good but its not disengaging enough so it drives the rear wheels all the time.
Everything on the truck is set exactly as the manual calls for. Its been run about 5 tanks.
Thanks for the help in advance. I looked all through the xxx thread and picked up enough to fix my other issues but this is just plaguing me.
