RE: Can the Hangar 9 Cessna 182 be converted to EP?
Well I found out some of the answers.
The contoller I will be using will shut down the motor before the voltage goes too low. I can chose if I want the motor to shut completely down or throttle back to slow ...allowing me to land.
My controller can be set up by autible "beeps" or I can purchase a "programming box" from Hacker which shows readouts for setting up the controller.
Hacker reccomends you not run the motor full out even if you are flying aerobatic planes. The motor has more than enough power(if you use the correct motor/controller/batteries).....on my plane I should have no reason to run full out.
