CG Ultimate setup advice & a few questions
OK, i've spent the last 4 hours reading through all the CG Ultimate threads (ok, a lot of them) & have a pretty good feel for what I need to purchase but would really appreciate any advice you fellow Ultimate owners/builders could give.
I have read that there are older & newer versions of the CG kit, and want to ensure that I get a newer version. I'm assuming that if my LHS ordered one or if Tower has it, that it will be the newer version. I couldn't really find a definative list of what's different about the old & new one; does anyone know where to find this info?
Here's what I have planned so far & some of my thoughts as to why.
Saito 1.25 (more power, oooh oooh oooh) (ok, & it's only 4 ounces heavier than the 1.00) (no clue what prop to use)
Futaba R127DF(FM) Receiver (should I upgrade to PCM? is it worth the extra money?)
5 x S3050 Digital MG Servo's (72 oz/in.) Will use dual servo's for Ailerons & for the elevator. (is this enough torque?)
S3004 for throttle
NR4F 4.8V 1500mah battery (should I go to 6V for more torque?)
Sullivan Tailwheel bracket
Stansfibertech Cowl, wheelpants, & aluminum gear (are the TNT gear better, is there somewhere better for the fiberglass stuff?)
Thanks in advance.
