RE: Opensource CDI ignition
Hi javipallinux,
You could probably make this work on 12volts by using a 7508 voltage regulator to drop the 12 volts to 5 volts.I have another circuit that is designed for 12 volts.Here it is.It would be easier to just add the 5 volt voltage regulator.
