Hi chuck,
I am not Bill, but I am sure I can help you.
It won't matter what order you do these mixes in, but on your Pmix 5, if your 2nd servo is not following the Master of the previous mix (Pmix 1 or 2) then you would need to turn your Link function on in that Pmix.
Lets say you have a mix of two servos, and you want to create a second mix, with another channel as master and the first two servos following. To make the "slave" of the first mix follow in the second mix, turn Link On.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Futaba Service Center USA
ORIGINAL: chuck l
I'm having a programming issue that I need help with. I have a PCM receiver in the GP Giant Big Stik with the flaps slaved to the ailerons. Each control surface is on a separate channel, with the flaps in channels 5&6, so PM1&2 are used to slave them to the ailerons (Ch1). I'm now trying to slave the ailerons to the rudder using PM5, however, only aileron (Ch 1) responds; flaps (Ch 5&6) and aileron (Ch 7) do not respond. Ail-Dif is turned on.
After an hour plus of programming using a different model, I found if PM5 was programmed first, followed by the rest of the PM's, than things work right. Am I missing something, or is there a sequence in which the PM's need to be done? My manual is at home, and I'm stranded in Florida for 5 more weeks.
Chuck
