RE: Need help with 4-tec
your transmission gears are messed up. if the gears are binding a chance they are sitting crooked. sometimes the set screw backs out of the car and makes the gears bind up. anyways take of your transmission gears and inspect the 1st and 2nd transmission (the little silver discs) if they are bad you might have to replace them they are usually 16 dollars a piece. might be the problem.
