ORIGINAL: dionysusbacchus
the Hellcat had a bit of forward rake in the gear. They were not at 90 degrees, for those that have installed the Century Jet gear did you modify the mounts in any way or did you just install them on the stock rails?
My stock CJ retracts were 93 degrees. I just epoxied in blocks of wood to build up the stock mounts and installed them in. No tendency to nose over, even when I had 3" wheels.
