RCU Forums - View Single Post - flutter
Thread: flutter
Old 11-24-2002 | 07:21 PM
CAP232CM's Avatar
CAP232CM
My Feedback: (8)
Default flutter
Do you have a lot of gap between the control surface and the trailing edge of the wing? You might try sealing the gaps with packaging tape on the bottom. Deflect the surface all the way up, then install the tape that way it won't bind up.
Also sounds like above mentioned, too much slope in your setup or your servos gears are stripped.
