ORIGINAL: Plane Insane
First, here is a detailed description of the process:
http://www.rcuniverse.com/forum/m_2887496/tm.htm
If you've made it through that process checking that your internet connection is not timing out or stalling is first. If the connection is not interupted, check if there is a pop-blocker or firewall stopping your progress?
What exactly is the error you're seeing?
As I said: "error saving file to disk" is the message....
