Hi Lee,
I am sorry if I misunderstood you, if you are not able to use the Up or Down mode keys to toggle through the different menus, then this needs to be sent into us if you decide to do this. You can check out our flat rate fees and print out a "return for service" form at our site on:
http://www.futaba-rc.com/service.html
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Futaba Service Center USA
ORIGINAL: lrr
Krysta,
Thanks for the suggestions. I didn't describe the problem exactly (or it is doing something slightly different today). Pushing both MODE keys, or pushing either one, causes the standard display (with battery level) to toggle the display to the ATV screen. But, pushing the DOWN key returns display to the startup screen. All I can do is get the display to toggle between these two screens.
I am sure the transmitter has a real problem. Will try to decide if it is worth pursuing getting it repaired.
Lee
