I've done it and it is a envey of the planes. Have over 30 yrs Xp, and this is one of my favorites. Added 1 -1/8 full stip aileron, tail dragger, with pull pull, flat hershy bar flat wing, 1" on the rudder. Pure cross control flat turns, Full side slips, all aerobatics. On a worn out 25, Slow, rolls, slow in tight flight. Do not loan out your plans! You will have to add in a traling edge longitudinal balsa spar.
It' will not be the last one you build you will love it that much. Did one in translusent yellow, yellow fiberglass pushrod to ele, and yellow pull pull sulivon wire.
