RCU Forums - View Single Post - need help with .40 GP extra 300
Old 11-25-2002 | 07:53 PM
frcac
Default Rudder servo
capnic: hm, that Graupner C-5007 has almost identical torque. It might help you with that last quarter of knife edge looping if you installed C-5077 (5.5kg versus 3.5kg).
I will check the CG location and will get back to you. Where do you have your CG?
As far as props are concerned - 11x5 will make the most out of OS .46 FX. If you use higher nitro content (15% and above) try 11x6 - thrust difference is very obvious.
Sašo
