need help with .40 GP extra 300
I can already see that people are interested in what I do. This is very must the same reaction I get at the field. I enjoy buying a plane that people already have and flying it better (WITH MODS), I know its mean but its fun. To start with the questions I don't know what my plane weighs but I can tell its to much It would be able to 3d without mods if it were lighter. Da king I think that your elivator looks good try it because you can always go bigger. And Walls are doable but dangerious the third flight a gave one a try and broke the stabilizer the only thing holding it on was the monokote. Luckily I was able to get it down without a problem. So I put fling wires on it and haven't had a problem. Da king what engine are you going with it better be big! This bird is TAILHEAVY.
Capnic The elevator was crazy and alot of work I moved the stabalizer forward added an inch along the entire span and on the sides of the stabalizor has the elivator to WATCH THE FLUTTER. Rudder I added about two inches to the top (TALL) and about 4 inches to the bottom (WIDE) But the shap stays the same. I will try to get som pics but no digital or scanner If you want I can make a diagram in paint shop and send it two you with the dimensions. And last the weight on this plane is bad so lighten it or else. Any answers to My question???????????
