RCU Forums - View Single Post - 3racing extended chassis for revo
Old 01-21-2006 | 05:39 PM
A.B.U's Avatar
A.B.U
Default RE: 3racing extended chassis for revo
ORIGINAL: Haulin bass
3 cm is over an inch genius, why dont you ever try something before making a comment?
Have either of you drove a high powered stock chassis revo compared to a simillar truck with an extended chassis? Nope because if you did you know it would make a 2-3 second diffrence per lap.You can accellerate harder, pound the rough sections even faster, your more stable in the air, and less likely to traction roll.Im no pro but I can easily tell the diffrence between when Im running my ext or standard chassis
I wish people like you would learn to actually make sense out of something. I meant an INCH ADDED ON to the 3 CM. "genious" And have I driven a High Powered sotck length chasised REVO? I wouldn't say NOPE to that. I have driven one, and IMO Longer is better. And uh, a longer chasis is more stable at higher speeds. Unlike a smaller chasis, again.. "genious". BUT a shorter chasis is better on a tighter track.
