RCU Forums - View Single Post - Opensource CDI ignition
Old 01-21-2006 | 06:29 PM
  #66
javipallinux
Default RE: Opensource CDI ignition
Hi, this circuit dont not work's like CDI??
it's more TCI no?
ORIGINAL: c_moore
Hi javipallinux,
You could probably make this work on 12volts by using a 7508 voltage regulator to drop the 12 volts to 5 volts.I have another circuit that is designed for 12 volts.Here it is.It would be easier to just add the 5 volt voltage regulator.
