RE: LiteFab Covering?
I have one in the works now with the Lite-Fab and Jerry's paint. The fabric is from England, so I suspect it is -Tex in ancestry. Went on very easy. The seams are a bit thick, if you will. I put no clear base coat on it-just color as Jerry advises. After four brushed color coats and wet sanding, it is slick as a button and ready for trim color. The paint seems expensive, but four coats on a 54" span wing used about 3 ounces of paint. I plan to brush the trim, probably add some vinyl sticky numbers and spray the clear for gloss. So far, I'm very pleased. It's unique, but now that I'm figuring it out, I think it will be very good.
