RE: Diff Cup Mod
Alvinl, thanks for the advice, i will try that.
I have a dremel so I will try that. Did it weaken the fitting any? How did they hold up. Anything has to hold up better then the factory ones. I am gonna stop and get the fittings in the morning, and try it out before i take the truck out tomorrow.
Hopefully i can run the truck without any problems!! I haven't even had the body on yet still working on my carb adjustments some. Got all figured out but the high speed, and I think that is cause i'm not letting enough fuel into the carb for high speeds.
Any of you happen to see the OS .18 that went on ebay for like 60 bucks?? If I had trusted the guy broke the engine in right i would have snagged that.
Also saw an MT2 and a buggy it looked like both together plus tools and some parts for 160. All the truck needed was Dif Cups.
Thought i'd share that.
Thanks Again
Tiny
