RCU Forums - View Single Post - 3 blade prop on your hare?
Old 01-22-2006 | 02:34 AM
Tired Old Man
Default RE: 3 blade prop on your hare?
I'm not going to comment on the 24" prop thing. They work great on 60cc and up size engines.
The three blade props, properly sized, will usually provide a tad bit better vertical performance, but don't brake as well on the down line. The noise level will drop a little, and the rpm numbers will be similar to what you have with a two blade.
To change from a 2 blade to a 3 blade, drop one inch in diameter and add one step up in pitch from what you had with the 2 blade. The size steps don't always work out when transitioning from 2 to a 3, so the pitch part often needs to be tempered a bit. Bear in mind that spinner costs will go up, along with a significant rise in prop cost,
