Can a TE be removed with debonder ?
I use MEK which is reactive to the glues. This was noted on many of the earlier bottles to be used if you glued your fingers together, and have been using it since as it is faster. With a eyedropper, just add a few, and then begin working the joint. It will come apart within 1/2 minute. Let the joint dry, and glue in the correct part.
Anything less seems to be submissive.
Wm.
