RCU Forums - View Single Post - PCM will it help
Old 01-23-2006 | 10:09 AM
flyjay77
Default PCM will it help
plane - G/P Christan Eagle
Engine- Brison 3.2 22x8 prop
survos - Hitec 635HB high torque 7 total
throtle survo - futaba 3003 standerd 1 total
RX- Futaba FM it came with the radio ?
Battery - RX - 6v.1650mah JR nimh --Eng- 4.8v.1830mah Hitec nicad-- Smoke, 4.8v.500mah Futaba nicad
smoke pump -- sky writer
Futaba SR10 survo reverser on the evevator
I have a 3 Y's in the wing , 1-top ---1- low --- and 1 goign to the RX,
I have 5 12inch extensions , all standard
EVERYTHING IS NEW !!
all conections are heat shrink together and tight I thought ,and it seems to only happen in the fuselage , the wing seems to stay still , does this help you any ?
I am getting a clitch in my fuselage when I do a rang check I start to get a little @ 15 paces and alot @ 30 paces , when I start to put the antenna up it stops , any help?
