RE: my savage shakes alot
I experienced wheel problems initially, only do discover the culprit is the bolt screw that hold the wheels tightly in place. The bolt screws hav a flanged lip and this does not cover the entire surface area of the mounting point in the wheel. So when you tighten it, excessive force drives the nut into the plastic deeper than it ought to be thus causing wobbly wheels. The best solution is to look at the surface area where the nut seats inside the wheel and buy inecpensive washers which will help spread the load over the plastic surfacr area in the wheels and then tighten the nut. This worked an absolute treat for me.
