RE: front end alignment question
set it at normal ride height w/ tires and rims mounter. use a 2x4 and an rpm camber gauge to set both toe and camber front and rear. very simple to do!!! try -2 degrees camber all around, -2 degrees toe in on the rear, and 0 degrees toe in front
