RE: Edge 540,Which servos?
I assume you are not planning on doing 3D. Standard servos and 3D throws don't work out well at all.
Even for normal sport use, you probably ought to go with a higher torque servo for the rudder. For the elevators and ailerons, if you get the mechanical advantage correct, the standard servos should be fine.
Jim
PS: I notice the DS537 has been discontinued. I wonder why.
