RCU Forums - View Single Post - Multiplex Magister RTF
Old 01-25-2006 | 02:16 PM
  #144
javiergarzab
Default RE: Multiplex Magister RTF
Carl, you wrote: "Loops are doable but rolls are scary with the ailerons limited to stock capability. If I cut them off and hinged them I think rolls would be easier."
I've seen a stock magister from a friend perform the rolls flawlessly. He, Alejandro, makes the rolls after getting the nose a bit up and he almost doesn't mess with the elevator or rudder while doing the roll. I can tell you that from ground his rolls look perfect. He loses almost no altitude, and keeps a very straight path. I hope that encourages you to.
I've had some very bad rolls while messing too much and too early with the elevator and rudder. I've also noticed that using 3/4 of the ailerons stick works best for rolls. But I share your point, My worst fear moments with the Magister have been doing rolls.
Javier
