RE: PCM will it help
You may wish to get the receiver antenna out of the airplane and as far away from other servos as possible. This can help you determine if the problem's actually in the receiver. It may also be that the high-torque servos are causing difficulties with the NiMH battery pack. Some NiMH packs cannot deliver high-enough current to drive high-power servos.
