RCU Forums - View Single Post - Realflight G3 question??
Old 01-25-2006 | 03:13 PM
tuwood's Avatar
tuwood
Default RE: Realflight G3 question??
ORIGINAL: Bigblock 396
How do I make changes to a aircraft in the edit aircraft on a G3 sim ? Do you need to open a file and save the changes or will it save them automatic. Im a newbe a would like a step by step Thanks
When you modify an aircraft, such as putting a different engine or a different prop on it you just save the changes and it will prompt you for a name.
Then that plane will be available to pick from your custom planes.
I didn't do a lot of tweaking on them other than making some of them bigger & swapping out engines & props.
