RE: Programming ESC in PZ Typhoon 3d
The directions are pretty straight forward.
Hold the throttle stick in the full up or full throttle position, and plug the battery into the rx.
Wait 5 seconds, rx will beep 3 times, confirming it's in the programming mode. Within 3 seconds of hearing the 3 beeps, move the throttle lever to 1/2 position. Rx will now go throught the programming menu. First one is battery cut off. First option is lipo. Rx will beep one time.
With in 5 seconds, move the throttle stick to full throttle position, hold for 1 second then return stick to 1/2 position.
Power down the rx. Power up the rx. and you are done, and ready to fly.
