RCU Forums - View Single Post - Duel Elavator servo setup...Need help
Old 01-25-2006 | 07:12 PM
more power
Default RE: Duel Elavator servo setup...Need help
NOT SURE OF WHAT RADIO YOU HAVE BUT A Y HARNESS IS YOUR BEST BET A SLOW SERVO MIGHT BE BECOUSE OF A WEAK BATTERY SHOULD RUN A 6 VOLT BATTERY ON ANY HIGH PERFORMANCE PLANE OR REVERSE ONE SERVO IN THE PLANE HAVE RUN MANY DUAL SERVOS ON ELVATORS , COULD BE A BAD SERVO // CHANGE IT OUT FOR ANOTHER ONE AND TRY AGIAN GOOD LUCK
