RE: HELP, REVO Problem withtranny, diff, clutch????
Cant believe I didnt notice. It seems though Ive lost one of the three pads behind the Spur at the slipper. How the f$#@ does this happen?!
I take it that that would mean my spur is loose and thus causing this problem. Do I have to take apart the entire slipper clutch assembly to install a new pad? When I do install new pads, would the slipper need to be re-adjusted?
Seems like a hell of a job. But I guess if I can pull apart both diffs front and rear in less than an hour Im sure I could do this. Plenty of practice makes perfect. When I do install new pads, would the slipper need to be re-adjusted?
Thanks for your help,
Dave
