RE: Its to cold outside
Take a ball point pen apart and use a peice of the tube that holds the ink. Push it down into your water line and hook back up to the fitting. I haven't tried it myself but it would definately restrict water flow. Or, you could get a tiny brass valve from a plumbing supply store (Home Depot maybe). This would allow the water restriction to be adjusted so you can find just the right flow for the water temp you're running in.
