RE: Duel Elavator servo setup...Need help
Bassicly My radio cannot be setup for duel elevator servos, I messed with last night for over an hour.
Heres what happenes, I go into my mixing options and set a slave channel to my elevator, I chose channel 5 then later used 6 (didnt seem to matter what channel i slaved)
Then after i did that I went and reversed the slave servo which was controling the left elevator half, so both were moving the right direction after doing that.
The problem is when i go to trim out my elevator only the right half trims out, that left half(the slaved half) dose not trim out, plus the the slaved half only has about 3/4 the amount of throw of the right half, my hardware settings are exactly the same.
At this point im just gonna have to go buy a reverser, seems stupid that the Eclipse 7 cant even do something as simple as duel elevator servos.
Thanks for all the help guys always appreciated [8D]
