RCU Forums - View Single Post - question regarding the pull pull mechanics
Old 01-27-2006 | 12:15 PM
Tired Old Man
Default RE: question regarding the pull pull mechanics
If the side at full deflection has only a little slack, don't worry about it. However, if the tension becomes so loose as to let the cable drop down, then you should correct it.
