RE: control help
thats hard for us to tell you.. best way is to use trial and error.
if you go to controls then analog control select joystick interface. now click mapping/calibration
you will now see 8 blue/white bars on the left side on the little window. move your analog stick up, down, left, right to see which stick movement goes with what channel moving up and down as you move your stick.
now to the left you will see a list of controls
rudder should be on left side of the controller and it should be set to the channel that your left side stick works with when you left or right
rudder allows your heli to rotate left and right 360* with the horizon
throttle should also be on the left side analog stick. that controls your take off or landing. move it up and down and see which channel that is on then put that into your channel box on the left side of the mapping/calibration window
elevator should be the right side analog stick but this time check the channel that moves up and down when you move your left stick up and down
elevator controls your heli nose down or nose up
aileron is your slide left and right stick which should be your right analog stick. move your right stick left and right and see which channel that is on then put that into the ch box on left side
you might have to reverse some of the controls to get it to work correctly.. just go trial and error method.. it's really not that hard to set it up.
