RE: Big TV for AFPD and G3
you do have to plug the cable into the TV out port on the video card...
BUT, then right click on your desktop, go to Properties, then go to the settings tab, and there should be a drop down to select what display device you want to use, if not, click the Advanced tab, and you can set up another monitor (the tv) there.
I like to set my resolution to twice as wide as normal, so i can slide AFPD over to the TV (my monitor and my TV are only about 2 feet apart, so it works nicely) and i can keep up RCU or somthing else on the main monitor.
hope it works,
scott[8D]
