RE: Rolling issues with Comp ARF Impact
Adrian,
I am not sure what is happening in your instance but if it rolls well in downlines but a little funky in uplines then it must either be a thrust issue or you may be using a little rudder to throttle mix to correct for vertical upline tracking. Lets face it the only difference between a model going up and coming down is power. Every other variable cancels out.
Regards,
Peter
