RE: NEW QUEST
Almost finished. I put a ST 90 in it with the head at the 7 oclock position that makes the muffler
centered on the bottom. Put the rudder and elevator servos all the way up front. used a carbon fiber arrow shaft for an elevotor pushrod, the throttle servo is on the motor mount. the battery is up against the fire wall. the receiver is on top of the fuel tank compartment. I moved the motor out to 140 mm. but it should all work. It looks likes it going to be right at 8lb. So it looks like it will be a good intermediate/pattern trainer for me.
