RCU Forums - View Single Post - Sukhoi SU-26 MX build
Old 01-29-2006 | 10:17 PM
  #203
Not24's Avatar
Not24
Default RE: Sukhoi SU-26 MX build
I decided to mount the elevator servos in the tail. I have staggered them in Z which will allow me to use a conventional Y harness. The rudder servo is in the stock location, without the riser blocks. My finishing materials will be here tomorrow, so I'm guessing about 3 weeks to first flight.
Couple of questions.
What type of hinges are you using?
Are you going to use foam tape on the wing saddle? mine is a little loose up front.
