RCU Forums - View Single Post - Sukhoi SU-26 MX build
Old 01-29-2006 | 10:28 PM
  #204
Ballistic Insanity's Avatar
Ballistic Insanity
Default RE: Sukhoi SU-26 MX build
Well Huges I am going to follow in your steps on the ailEron Servos... Needs a little reenforcment. I have a question about there installation however. Do you have to cut out a bit of the sheeting to get them to fit? It looks like I am going to have to. That being the case bring me to conclude that unless you build an access cover you will not have a clean looking bottom of the wing. That is where your going to paint it correct?
Not24,
I was just going to use the stock hinges. What were you thinking of using. I am good at stealing ideas from others to make my plane better... My wing sits a little loose as well I was going to add a piece of Ply to lock it in however some foam tape would do just as well...
I got all the tail surfaces covered tonight. I will post some pics later of the progress.
