RCU Forums - View Single Post - Checking batteries
Old 01-30-2006 | 06:37 PM
Geistware
My Feedback: (16)
Default RE: Checking batteries
Get a flashlight bulb (4 cells) and put wires on it. Connect a resistor to the wires and a connector to plug into your pack. This is a cheap way to see if your pack will handle a load.
If you use a 5-10 ohm resistor and the bulb still lights then you should be OK.
