RE: Ulitimate setup
Bevo, yes its the profile Ultimate. So do you think that the 12x3.8 would not be good enough? Do you think that kind of prop, 12x3.8, would prematurely damage my motor? No, I have not flown it with that prop but like I said, the 11x4.7 seemed to me to do fine. I think that I may know someone who has an AMP meter to check it at the field.
Tell, me Bevo. During inverted flight, did your aircraft want to climb towards the gear without input. Mine does and I actually have to pull back on the stick for level inverted flight vice push. What about hovering, the motor seems to create a lot of torque and it really wants to torque roll right off the bat. Now, I am not very good at hovering but I am still trying. Also, my aircraft seems to do a knife edge better on the RH side better then the LH. Was yours like that as well?
Thanks again
