RCU Forums - View Single Post - nuttin special
Old 01-31-2006 | 01:59 AM
JB Flies
Default RE: nuttin special
The Nuttin ' Special kit has made its way down to New Zeland where I live. In fact I recently "aquired" a slightly battered but almost complete ARC kit, rescued from a trip to the dump after a shop closed! It looks real nice and reading the forum they seem to fly well so its this kit's lucky day as I intend to finish it off. However there are a couple of problems. While the fus, wings, tail bits are all there and in good order, there appear to be some bits missing from the kit - most importantly the instructions/plans. There are a few photocopied sheets which seem to cover most things but it would be helpful if I could get access to some plans or at least be able to ask someone for clarification where needed.
One area that needs clarification is the undercaridge which is missing entirely. Dimensions etc to help make up new pieces would be helpful. Also was the kit supposed to come with the bits to build up the tank box and engine mounts? If so they are missing also.
What engines are recommended? Is a 60 2C sufficient?
