RE: Decals for Ultimate
Yes.
Lay the decals down on a table with the backing paper still attached. Take the sheet of clear transfer medium and remove the backing paper. Lay the transfer sheet down on top of the decals so the decals will adhere to the transfer sheet.
Turn the whole mess over now and peel away the backing paper from the decals, pulling in a sideways manner so you do not pull thedecal off the transfer sheet.
Nowlay the transfer sheet/decal down on the plane in the desired location. Use a rounded tool like the base of a small screwdriver to rub the decals against the plane. As you rub it adhesive is activated.
Finally pull away the transfer sheet, again in a sideways manner leaving the decal behind.
TF
