RCU Forums - View Single Post - Comming back to planes...maybe
Old 01-31-2006 | 12:58 PM
bruce88123
Default RE: Comming back to planes...maybe
ORIGINAL: Mode One
What are dual ailerons? All the airplanes I have ever known have two ailerons. Is this what you are calling the flaps, when they can also act as ailerons and are not "flapping"?
The use of a telephone might help you get in touch with an instructor. If at one of the fields and no instructor is there, ask the fliers there, who is a good instructor and if they can give you the instructor's phone number.
It is not law that you must fly with an instructor. Local clubs may have rules that this is how the process works for that club. The club you describe as not actually being a club likely has no such rule. Still, going up with an instructor is a good idea and if you can arrange it, I would do so, unless you have confidence in your abilities to be successful!
Dual ailerons - meant using 2 servos in this case. One in each wing.
Yes - call an instructor
Fly whenever you want? NOT!!! The controlling agency here in the U.S. Navy. It could cost ALL of them to lose the use of this excellent facility. I'm sure you want to rethink this suggestion a bit.
