Covering Help!
I use a heat gun on the corners and edges, it works a little better than the covering iron. Also, a heat gun will take out the wrinkles and creases a little better than a covering iron. Be careful though, its easy to burn holes in the covering, if you try a heat gun... make sure you have it on "low" setting and hold it back away from the covering a little bit.
