RCU Forums - View Single Post - Covering Help!
Thread: Covering Help!
Old 11-30-2002 | 12:47 PM
$ircra$halot
Default Covering Help!
Hey PaPa: To check for proper heat. Use scrap balsa, iron some monokote down. If it wrinkles it's to hot. Now peel up the monokote, it should have some balsa stuck to it, if not turn up the heat a little at a time till it does. Definately fuel proof, the epoxy method mentioned earlier works well. Good luck. Garry
