RCU Forums - View Single Post - Throttle trim adjustment question?
Old 01-31-2006 | 09:53 PM
joebags
Default RE: Throttle trim adjustment question?
ORIGINAL: twgreen3
Your trim has to be set to zero or your opti drive will think you have the throttle on and not let you shift. My experience has taught me that there is not need to ever adjust the throttle trim unless your servo is way out of whack. All of the idle and tuning issues should be done on the carb and not with the throttle trim. If you use the throttle trim to adjust the idle you are effectively eliminating the throttle stop screw. I hope this helps.
Thanks but my Throttle Idle trim was set slight right of zero from the factory but I moved it then I tried to move it back to where is was set from the factory but this was not precise. Any other adice? I guess I can maybe set it to zero and then reprogram the opti drive per the instructions?
