Inverted Engine Problems in a Banchee
I have an o.s. 46ax invert-mounted in a new banchee. I am having problems with flooding at an idle, and cannot adjust the carb to take care of this problem. The tank does sit higher than the carb and due to the construction of the plane I cannot lower the tank, nor can I change the engine orientation. The engine worked fine in a different plane mounted carb up. Any help is appreciated.
