RCU Forums - View Single Post - Does size REALLY matter?
Old 12-05-2002 | 09:45 PM
FLYBOY's Avatar
FLYBOY
Default Does size REALLY matter?
Can't see you milling around with a mustang. The horse wants to run. Watch the flaps on takeoff. If you take off with them on, and try to climb steep, you could end up in a tip stall, spin situation and that will be the end. Make sure you climb out fairly flat till you learn the flight tendencies of the plane. Have fun
