RCU Forums - View Single Post - couple of questions
Old 02-01-2006 | 06:38 AM
Dr1Driver
Default RE: couple of questions
If it's a composite engine mount, you can also use #4 or #6 sheet metal screws. Drill the appropriate tap hole, lube the screw with a little grease (NOT petroleum based) and use a lock washer under the screw head. Dave Brown uses this method on his engine mounts, and it works great!
Dr.1
